Grabbing a thumbnail pic from Final Cut Pro? at DVinfo.net
Final Cut Suite
Old May 5th, 2008, 11:05 AM   #1
I know this is a simple process but cant remember how it is done. Can anyone tell me how to grab a screen shot from Final Cut and convert it into a jpeg pic?
David Allen Smith is offline   Reply With Quote
Old May 5th, 2008, 12:27 PM   #2
Shift-N creates a freeze frame in the Canvas. You can go to File > Export > QuickTime Conversion and export it as a JPG (or anything else.)
Edward Carlson is offline   Reply With Quote
Old May 5th, 2008, 01:44 PM   #3
Thank you very much.
Old May 5th, 2008, 03:41 PM   #4
You can also do the OS X screen capture (Command+shift+4) and get a screen grab, which will save a PNG so you'd have to open in Preview and save as JPEG (which I actually prefer because Quicktime conversion into still frame sometimes screws up the aspect ratio or shows interlace artifacts).
youtube.com/benhillmedia
linkedin.com/in/benhillmedia
Benjamin Hill is offline   Reply With Quote
Old May 5th, 2008, 03:44 PM   #5
I've seen that method go awry, though. If any overlays are visible, they get captured right along with the frame. I saw someone's video and all their still frames had the exclamation point or green check mark at the top because they didn't turn off the excess luma overlay.
Old May 5th, 2008, 07:46 PM   #6
Well, nothing's idiot-proof.
Old May 6th, 2008, 12:28 PM   #7
And once they do make something idiot-proof, they come out with a better idiot!
Paul Podraza is offline   Reply
