m2t to mov for fcp at DVinfo.net
Final Cut Suite
Old April 25th, 2008, 05:38 PM   #1
m2t to mov for fcp
Hey, guys. I got the DTE dr-hd100 firestore. For some odd reason, anytime I record with mov, my audio is jacked up. I use fcp to edit... however, if i shoot m2t, the audio is fine. But, as you all know, I can't import that to fcp. So basically what I'm getting at is, what program should I use to convert m2t, to qt at full quality so I can edit it in fcp? Well, that about does it. Thanks, dudes.
"Warriors... Come out to play..."
www.importexporthd.com
Douglas Joseph is offline   Reply With Quote
Old May 8th, 2008, 01:16 PM   #2
This what I use.
http://www.squared5.com/
David Allen Smith is offline   Reply With Quote
Old May 9th, 2008, 03:44 AM   #3
Or....
For a small fee, you buy the extremely robust and equally fantastic HDVxDV
http://www.dvdxdv.com/hdvxdv.html
But they both work very well.
Cheers,
Neil
Neil Rostance is offline   Reply With Quote
Old May 9th, 2008, 08:55 AM   #4
Originally Posted by David Allen Smith View Post
This what I use.
Dave, this will transcode M2T to .mov in a different codec (say ProRes, Uncompressed or AIC) but won't save the native HDV stream native to a .mov container file.
You could, if you have the patient, demix the M2T to M2V and AIFF, then open that file in Quicktime pro, THEN save to .mov file, but don;t know if this would avoid the issue Joseph is talking about.
Dylan Pank is offline   Reply
