Thread Tools
Search this Thread
Log & Capture window won't go away
Just wonder if this is happening to anyone. After I load a tape I can not get the capture window to close. I can still work in FCP with no problem, the capture window just falls behind FCP. The only time it goes away is when FCP is shutdown and then reopened. It doesn't mess with my workflow, it's just annoying.
Hi Chuck.
There's an update for FCP (6.0.3) which has just been released. Try it and see if it helps with the problem. (And if you're running on FCP 5 or lower, perhaps it's time to update.) |
