deinterlace for canon gl1 or gl2 at DVinfo.net
Final Cut Suite
Old April 10th, 2008, 04:27 AM   #1
Hello
I am working on videos from a canon GL1 and working on final cut 5.1.4
and I am exporting the movie for the web.Do I have to deinterlace, and if its yes at what setting?
thank you
Martin Labelle is offline   Reply With Quote
Old April 10th, 2008, 02:18 PM   #2
It depends what you shot it in. Did you shoot in 24p or 24pA? If you shot in 24pA - I'd recommend de-interlacing if you are going to output to some sort of video source or expect others to - that being said - If it is for youtube or similar, this is extra work.
As far as digital is concerned, QuickTimes don't care about framerate - the problems arise when you try to play out on NTSC / PAL monitors.
Long story short - for web - don't worry about it.
-C
Old April 10th, 2008, 04:38 PM   #3
@ Christopher - There is no 24p mode of any sort of the GL1 or GL2 (there might be Canon's old Frame movie mode). Anyway with a movie that has 24pA it's not de-interlace, it's pulldown removal. (Completely different thing and best done in cinematools).
@ Martin - If you're uploading to the web, the footage needs to be progressive or de-interlaced, even for Youtube. What settings are available to you? I recommend downloading Too Much Too Soon plugins and using the smart de-interlace filter.
Dylan Pank is offline   Reply With Quote
Old April 11th, 2008, 01:17 AM   #4
Martin, I have actually gotten very nice results by letting Compressor handle de-interlacing when outputting for Web (see http://www.youtube.com/watch?v=FczftPs27NY for example)
Mike Barber
"I'm laughing to stop myself from screaming."
Mike Barber is offline   Reply
