Colour pass at DVinfo.net
Final Cut Suite
Old April 7th, 2008, 12:22 PM   #1
Colour pass
I wanted to ask if you can let the orange colour of a General Lee Dukes of hazzard car show through and everything else B/W in FCP2?
In Premiere you added a colour pass filter and selected the colour to show through, how and can this be done on the mac?
Paul
Paul Gallagher is offline   Reply With Quote
Old April 7th, 2008, 12:42 PM   #2
You could accomplish this using the 3 way color corrector - select all colors other than the orange, using 'Limit Effect' towards the bottom of the visual 3 way color corrector display.. Then, set Saturation to 0. Done!
I just did it to doublecheck the names of things such as the Limit Effect - took under 30 seconds to remove all color other than greens on a video.
C
PS - Meep... FCP2? I misread as FCS2. The step-by-step applies to FCP6.... Maybe still the same... (or similar? I hope?)
Carl Middleton
Whizkid Mediaworks
Carl Middleton is offline   Reply With Quote
Old April 7th, 2008, 01:30 PM   #3
Thanks Carl,
I was directed to this link that does the job http://www.kenstone.net/fcp_homepage...ille_look.html
Check it out, it does more or less just like you explained, thanks for your help.
Paul
