Help! with mpeg encoding at DVinfo.net
Final Cut Suite
Old April 5th, 2008, 12:54 AM   #1
Hi,
Is there any way of exporting from FCP a mpeg 2 file with the sound embeded?
In PPro there is a multiplexing opion where you can embed the sound in the video file.
I have Final Cut Studio 2.0.
Thank you very much for your help,
Eugen
Eugen Oprina is offline   Reply With Quote
Old April 5th, 2008, 02:29 AM   #2
1. Right click on the sequence and select Export -> Using Compressor
2. In compressor select New Default Setting and choose MPEG 2
3. In the Inspector under the Encoder settings in the Extras tab you have a option to use Multiplexed Audio.
This would be in Compressor v2.3, I haven't yet upgraded to Final Cut Studio 2.0 so I'm not sure everything is in the same places but the option should be there somewhere, hope this helps.
Melvin Torrens is offline   Reply With Quote
Old April 6th, 2008, 04:12 PM   #3
Melvin,
You are great.
It works perfect.
Thank you very much.
All the best,
Eugen
