How do I sync ext audio with many video clips using timecode? at DVinfo.net
Final Cut Suite
Old March 16th, 2008, 08:31 AM   #1
Hi,
I have recorded separate audio containing three audio channels; one stereo pair (as two mono channels) and one mono track from a lavalier mic.
The video has two audio channels from the built in mic.
The timecode from the camera was wirelessly fed to the audio recorder and automatically started and stopped the recorder with the camera.
Do you experts out here have any opinion how these tracks could be synchronized with the video tracks from one camera?
I know I can select one video clip and the corresponding three audio tracks and "Merge clips" using timecode. However, it will only do one clip at at time and I have to manually select the corresponding clip.
Is there a faster workflow available? Perhaps by adding all video clips in a long sequence and then let the program position all audio clips under the video according to the timecode somehow?
Thankful if you have any good idea. /Johan
Johan Forssblad is offline   Reply
