Can I use IOHD for a DVCProHD sequence? at DVinfo.net
Final Cut Suite
Old February 29th, 2008, 04:39 PM   #1
Hi,
I'm wondering if IOHD will output a DVCProHD sequence for a client monitor (via component or SDI) or if this functionality is limited to ProRes sequences only. Could I take all my DVCProHD footage and put it into a ProRes sequence with no loss in quality? Apologies if these are noob questions -- couldn't find the answer on the AJA website. Thanks!
Peter
Peter Richardson is offline   Reply With Quote
Old March 1st, 2008, 08:41 AM   #2
Yes. The IO HD will playback DVCPRO HD sequence (but it is intrinsically a ProRes device and so the data will be transcoded thru ProRes in realtime in hardware as part of the signal path)
Andy Mees is offline   Reply With Quote
Old March 1st, 2008, 02:20 PM   #3
Thanks Andy!
