FCP capture question at DVinfo.net
Final Cut Suite
Old February 25th, 2008, 12:14 AM   #1
MPS Digital Studios
In the past, I was able to play JVC HDV 720p30 tapes from a Sony HDV camera, and vice versa, plus I've been able to capture. With 6.0.2, I cannot; am I crazy or is there a work around?
Heath
My Final Cut Pro X blog
Old February 25th, 2008, 10:26 AM   #2
Go Go Godzilla
Images: 15
That's interesting because unless I'm mistaken, the GOP structure between Sony and JVC is different.
I rarely see HDV timelines unless I'm helping out another editor but I beleive FCP6 does have specific capture presets for all 3 HDV flavors now, JVC, Canon and Sony. Check the online help in FCP along with the HDV Workflow white-papers available from Apple's site, that will answer these questions succinctly.
Old February 28th, 2008, 09:33 AM   #3
I'm experiencing different behaviors on master to tape function than before.
Apple must have changed the program in there.
Kaku Ito is offline   Reply With Quote
Old February 28th, 2008, 01:07 PM   #4
Heath,
What Sony deck are you using? I've got a m10u and anytime I get a JVC HDV tape I've got to rent a JVC deck 'cause the m10u won't play it.
-A
Andrew Kimery is offline   Reply With Quote
Old February 28th, 2008, 04:47 PM   #5
Heath
Capture? How were you doing that? The only way I can get any Sony HDV equipment to play back JVC HDV is through the analog outputs. Perhaps the HDMI does too?
William Hohauser is offline   Reply
