Compressor - DOA - Page 2 at DVinfo.net
Final Cut Suite
Old February 16th, 2008, 08:51 AM   #16
Alkim, read carefully through these links. You can do it. You need to install the the previous versions using Pacifist
http://www.versiontracker.com/dyn/moreinfo/macosx/12743
Here is a link to a thread discussing the problem
http://discussions.apple.com/thread....rt=30&tstart=0
Here is the link to the library of versions
http://www.apple.com/support/downloads/
Here are the locations for the different systems
Panther: http://www.apple.com/support/downloa...orpanther.html
Tiger: http://www.apple.com/support/downloa...1fortiger.html
Leopard: http://www.apple.com/support/downloa...orleopard.html
Go get em' brother
Eric Gulbransen is offline   Reply With Quote
Old February 19th, 2008, 04:44 AM   #17
eric,
I downloaded the pacifist, then I downloaded the qt 731 and then reinstall compressor. restart the machine everytime. does not work ! If I open the compressor, sticker of the program stays, and then batch window does not open,
I ve read through the forum but they say about quictime does not play mpeg4 files.
before I install qt 7.4.1 compressor had worked.
I dont know what to do ? but I m losing times!
thanks,
alkim.
www.alkimmedya.com
Alkim Un is offline   Reply
