External monitor on an iMac 20" at DVinfo.net
Final Cut Suite
Old December 21st, 2007, 06:41 PM   #1
Hi,
I have one of the above flat beasts, and would like to use an external monitor/tv as a control monitor during editing.
I bought Apple's Mini-DVI to DVI converter and I also have the DVI to Composite/S-Video converter from Apple - but this doesn't fit into the Mini-DVI converter. There are 4 extra pins on the Composite plug and no room for these on the Mini-DVI to DVI converter.
How do you folks connect an external monitor or a TV to the Mini-DVI output on the back of the iMac? I looked all over the net to no avail, but surely someone must have come up with a (clever) solution....?
Peter in Denmark
Peter Erfurt is offline   Reply With Quote
Old December 22nd, 2007, 02:42 PM   #2
The 4 extra pins on the composite plug are the necessary pins for your purpose to carry the ANALOG signals to the S-Video/composite end. The mini-DVI to DVI adapter from Apple is a DIGITAL only adapter (DVI-D) and lacks the 4 pins which carry the ANALOG signal. I don't know whether the 20" iMac's mini DVI output carries analog signals but if it does then what you need is a mini-DVI to DVI-A (analog) or DVI-I (analog and digital) adapter. See the link for more information:
http://www.datapro.net/techinfo/dvi_info.html
P.
Pedanes Bol is offline   Reply With Quote
Old December 26th, 2007, 06:35 AM   #3
Hi Pedanes,
Thanks a lot for your reply - that cleared a great deal of the mystery :-)
And the link was indeed helpfull too. Never realized there were that many "DVI-standards". So now I at least know what cable I'm looking for, and hopefully I can get my second monitor up and running here between Christmas and New Year.
Once again, thanks for your help!
Kind regards
Peter
Old December 26th, 2007, 07:24 AM   #4
Hej
I have a IMac and I have a external monitor for FCP and Imovie 6 for color correcting etc. and I tap a signal via Firewire to a DV-converter box and from that to my CRT monitor.
You can also use a DV camera that has analog out as a converter
I donīt want to occupy the DVI port since I also shortly will get a second flat screen and then I need that port
Remember, that English is my second language.
Hans Ledel is offline   Reply
