Snap to markers setting? at DVinfo.net
Final Cut Suite
Old December 13th, 2007, 10:42 PM   #1
Couple things I can't find in the manual:
Is there a setting to snap to markers?
Also, is there a setting to center the playhead?
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old December 14th, 2007, 12:24 AM   #2
DVCreators.Net
If Snapping (n) is on you will snap to markers while scrubbing the Timeline.
If you would like to go to a marker use Shift up arrow and Shift down arrow for previous and next marker.
Hope this helps,
Guy Cochran
Old December 14th, 2007, 12:36 AM   #3
Thanks Guy,
The shift thing is going to be very helpful, but when I'm scrubbing it ignores the markers and just snaps to the end of clips. It seems like it should do what you're describing and as a default setting.
www.LegacyHDV.com
Old December 14th, 2007, 12:48 AM   #4
DVCreators.Net
By the way if you're on a marker and hit "M" again you can then Edit the Marker and give it a name.
What's the advantage of this?
Try control clicking in the ruler area of the Timeline and you'll the see Names of all your markers.
Guy Cochran
Old December 14th, 2007, 09:22 AM   #5
The one thing that comes to mind is that for chapter markers, these names are exported to DVD Studio Pro and become the default labels for chapter menu buttons.
Didn't know this - learning new things every time I visit this forum! :)
- Martin
Martin Pauly
Martin Pauly is offline   Reply
