Can you do "Close Gap" for multiple clips? at DVinfo.net
Final Cut Suite
Old December 12th, 2007, 07:38 PM   #1
I've been editing quite a lot of footage in the timeline and the resulting edited clips are all spaced out from one another and I want to remove the gaps between the clips but doing the right click close gap thing is very tedious and I think a waste of time... is there any way you can close all the gaps for a given region or selection on the timeline or is it only possible to close gaps individually?
James Whitmoore is offline   Reply With Quote
Old December 12th, 2007, 08:23 PM   #2
Only individually as far as I know. Try using the keyboard to speed up the process...the apostrophe key will move you to the next edit point, then Control+G will close the gap. Get into a rhythm with that and it should go pretty quick!
Mike Flynn is offline   Reply With Quote
Old December 12th, 2007, 09:49 PM   #3
"Select all" the clips in your timeline, drag them into a BIN.
Then open a new timeline - select all the clips in the bin - and drag them to the new timeline.
They'll import from the bin to the new timeline with no gaps.
Old December 18th, 2007, 01:04 AM   #4
slightly quicker tip: just click gap and then press delete/backspace key, much quicker than right clicking each gap and then clicking close gap
Brian Rossen is offline   Reply
