Capture Utility Beside FCP - Page 2 at DVinfo.net
Final Cut Suite
Old December 5th, 2007, 11:51 PM   #16
Dana,
I went with your option 2. When I purchased the upgrade to FCS I only installed it on one computer and left FCP5.1.4 on the other. Now I can keep my network up and running while I import on both machines.
Just out of curiosity, why do you need your airport on while you are importing. When I had the same version on both machines I would just turn airport off of one and capture to an external 500gb drive. When all capture was done I just hooked it up to my main computer via FW800 and after lunch all my footage was on one computer.
Good luck in whatever works for you.
Jonathan Schwartz
CA Video Productions
Jonathan Schwartz is offline   Reply With Quote
Old December 6th, 2007, 12:31 AM   #17
My Macbook Pro has only one firewire, so I cannot capture via firewire and go to an external. So I am connected via ethernet to my Quad, so it's the ethernet connection that won't allow it.
It would be far less expensive to go PC and convert, but the unknown is how long the converter would take with each hour-long HDV capture.
www.LegacyHDV.com
Weddings | Corporate | HMC150s | FCPX | Encore | Lion
Dana Salsbury is offline   Reply With Quote
Old December 6th, 2007, 03:32 PM   #18
How about a Firewire hub, or daisychaining the external drive and the camera? For this case, I'd even consider capturing to the built-in drive as opposed to an external scratch disk, and moving them over to the editing computer later.
I feel your pain, Dana. I, too, shoot with up to three cameras and routinely have six tapes for a single show that I record. The two things that have saved me so far are that I don't have more than two or three of those to cover in a single month, and the fact that I work out of my basement, so I try to capture during normal activities - capture one tape while cooking dinner, the next while eating, the third while I watch TV, etc.
- Martin
Martin Pauly
Martin Pauly is offline   Reply With Quote
Old December 6th, 2007, 05:19 PM   #19
What about Final Cut Express?
Chris Hocking is offline   Reply With Quote
Old December 6th, 2007, 06:49 PM   #20
That would only capture using Apple Intermediate codec. So not really different from iMovie, right? BTW, Dana, I still don't understand what's wrong with iMovie?
Dino
Dino Leone is offline   Reply With Quote
Old December 6th, 2007, 07:39 PM   #21
I downloaded and installed it. I got it to work after quite a bit of reading, but when I captured it came out as M2t (Vegas). Of course Final Cut will not accept M2t.
Are you sure it isn't usable if you just change the file extension? Isn't it a quicktime m2t file and therefore usable in FCP?
http://twitter.com/tedmcneil
Theodore McNeil is offline   Reply With Quote
Old December 6th, 2007, 08:12 PM   #22
Correct me if I'm wrong (I've never actually used the newer HD version of FCE), but doesn't it support native HDV as well as AIC?
Old December 7th, 2007, 12:49 AM   #23
Hmm...I'm 99% sure FCP doesn't support M2t. I'll try it. If it did/does, I would sell the MacBook and capture on my PC. I just don't want to have to convert anything after the fact.
iMovie gives me huge honkin' scratch files, and captures slowly. I.e., capturing an hour minidv can take 1.5 hours.
As far as daisy-chaining, my WD drives have problems doing it. Sometimes it works, but more often it doesn't detect the drive after a restart. Hit-miss quirks drive me nuts. A hub is a possibility -- perhaps the best.
www.LegacyHDV.com
Old December 7th, 2007, 10:25 AM   #24
No, it doesn't - otherwise this would be a great (read: cheap) way to capture to Dana's second computer.
Originally Posted by Apple Final Cut Express 4.0 User Manual
Editing HDV Using the Apple Intermediate Codec
Your HDV video is transcoded by the Apple Intermediate Codec during capture. The Apple Intermediate Codec is a high-quality video codec optimized for playback performance and quality. Although the data rate of the Apple Intermediate Codec is three to four times higher than the data rate of the native MPEG-2 HDV, the processing requirements to play back your video are less. Unlike native MPEG-2 HDV, the Apple Intermediate Codec does not use temporal compression, so every frame can be decoded and displayed immediately, without first decoding other frames.
- Martin
Martin Pauly
Old December 7th, 2007, 02:57 PM   #25
FCS2 is the first version of FCP I've owned. When was HDV capture included in FCP. I'm thinking that I don't need FCS2, but that an older version would do.
www.LegacyHDV.com
Old December 8th, 2007, 05:05 PM   #26
I believe that was first added in Final Cut Pro 5.0:
http://images.apple.com/finalcutstud...rs/HDV_FAQ.pdf
That was my first version of FCP, and I've been working with HDV natively ever since I got it. So yes, maybe try to snag a copy of FCP 5.0 on eBay...
- Martin
Martin Pauly
