FCP Sequence Preset with 25f Footage at DVinfo.net
Final Cut Suite
Old November 27th, 2007, 03:12 PM   #1
Hi All,
Firstly thanks for all the great info on this site, it is awesome. I am new to this forum and this may be a simple problem but when I capture HDV 25f footage from my A1 into FCP all fine, but when I drop the footage into the timeline it needs rendered. What is the correct sequence preset for the Canon 25f footage?
Jon
Jonathan Shaw is offline   Reply With Quote
Old November 28th, 2007, 02:48 AM   #2
Check your timeline setting, remove your footage from the timeline, and then go to the Sequence tab, Click setting , change your compression setting to the correct one that your footage is filmed in.
Then bring in your footage again to see if they are green, if they are still red, just remove them and repeat the steps above .
You cannot change the timeline setting when there is footage on it.
Website: http://www.Motiononcanvas.com Camera Operator/ Video Editor in Singapore.
https://new.cinematographer.org.au/m...713/david-chia
David Chia is offline   Reply With Quote
Old November 28th, 2007, 09:25 AM   #3
Moved here from Canon XH.
Old November 29th, 2007, 12:44 AM   #4
Just gone through all the HDV settings and tried still red...
Works fine with HDV 50i but not 25F
I am using FCS 5.1.4... is it only found FCS 6?
Jon
Old December 1st, 2007, 07:04 AM   #5
I've had no problems using 1080(p) 25f with the XH G1. I've used "easy setup" in FCS2/FCP6.0 at both HDV and DV (to allow footage shot in HD to be viewable in SD/ PAL 4:3). If you're "easy setup" is one of these I can't think of any reason why it's coming up as unrendered. Sorry Jon--not much help but just letting you know it works for me...
Jim Press is offline   Reply With Quote
Old December 1st, 2007, 04:59 PM   #6
Thanks, I have FCP 5 not 6 and there is a setting of 1080 p 25 which I have tried but no joy. Does the easy setup on FCP 6 actually state 1080 p 25 f.
Hopefully I won't have to upgrade just yet?
Thanks for your help
Jon
Update: Actually just tried again, re-saved and works. Have not idea what I was doing wrong
Thanks again
Cheers
