question about compressor and dvd studio pro?
I just finished a hdv project in dvd studio pro and I cannot burn it to a dvd-5 because it is 7.2 gigs in size is there a way in dvd studio pro to build my finished project so that it will fit on the dvd-5 with out starting over and importing it into compressor first and compressing to h.264 then sending out to dvd studio pro. Basically can I save my exiting project and just make it smaller so it will fit. Thanks in advance Gary Williams
Gary,
to make sure we are talking about the same thing: you want your DVD to be viewable on regular DVD players, right? Since you mentioned h.264, I didn't want to rule out the possibility of creating a data file and storing that on a data DVD. Either way, you will have to reencode your media with a lower bitrate to make the file sizes smaller. Did you create your media in Final Cut? You can use Compressor (stand-alone or invoked from Final Cut) to export and encode your media; there's a button to set "video" options which contains the bitrate settings etc. Your description was a little vague in terms of what your project consists of and how it was created, maybe you can share a little more and we can make more detailed suggestions. - Martin
Martin Pauly |
#3 | |
#4 | |
Second, to avoid the situation you are in right now, what I usually do is I define the chapter markers in Final Cut Pro, not in DVD Studio. Then from within Final Cut Pro, I export to Compressor, which stores the chapter and compression markers in the generated file. That way, if you have to do it again, your markers are still there. I don't know if it's possible in DVD Studio Pro to just "swap out" the MPEG-2 files, i.e. replace the old, large asset with a new, smaller one but preserve the chapter markers on your DVD Studio Pro track. Maybe worth a try. - Martin
Martin Pauly |
#5 |
I do the same thing you do set my markers in final cut first but I still have to chapter my dvd in studio pro though or I mean design the dvd. I guessI will have to do that over to bad.
#6 |
Gary,
sorry, I had misunderstood that in your first posts. Yes, chapter/index menus... Well, I am not sitting in front of my Mac, but you may want to try the following: In a backup copy of your project, in DVD Studio Pro, open the track that contains your feature. The timeline should have a video asset and an audio asset. Now, delete the video asset from the timeline. Then drag the asset back into the track timeline and see if your project still works, including the chapter menu buttons that link to that track. If that works, my guess is you should be able to drag another asset (namely the one with a smaller file size) into the track. This should retain your chapter menus. As I said, I haven't verified that this works, but I think it's worth a try. - Martin
Martin Pauly |
#7 |
Thanks Martin, I will give it a try tomarrow hope it works, I will let you know.
#8 | |
