getting good smooth slow motion shots?
ok i am having trouble getting very smooth slow motion in fcp. all ive done is just deinterlace then slow it down, is there anyway i can get it really smooth? i have a vx2100 and i always shoot at 60 fps
i shoot mostly skiing and snowboarding, and the shots i want arent that slowed down, like 60% at the most, usually 75-90. and i also want to get a shot of a gun action when its shooting, so like the slide going back or the shells coming out etc. so for that would i just shoot it at a high shutter speed? like 500+? |
Scott:
Shooting 60i at a high shutter speed will give you better slow motion. Using After Effects can also help you achieve the slow mo look you are looking for, provided you have AE. If not, I would try a shutter speed at 250 range and go up from there if you have sufficient lighting. John |
For what its worth Apple Shake and Twixtor both work pretty well with slowmo, although I find Shake's feature very confusing to work with. I always used them on 60i footage shot at 1/60 with very nice results. Not sure about faster shutter speeds
Don't deinterlace... Make sure that the footage is set up as interlace lower field. Make sure frame blending is set on.
Putting the shutter speed to 120/sec or higher does reduce motion blur, and makes the slow motion seem slightly clearer and less smudgy (and in my opinion better) as we're not used to seeing 360 degree motion blur on footage slower than 60i or 50i. Shooting 50% slow mo at 60/sec is like shooting 30p at 30/sec shutter. Going any higher will just introduce the same fast shutter effects that shooting at high shutter speed always introduces, but that might be cool for an extreme sports style. Alternatively you could run all your slow mo footage through something like JES de-interlacer... I think the gun shot you're talking about requires special equipment, it's the sort of thing that would require 120 fps at least. Your video camera is always shooting at 60 fields per second, unless you set the shutter speed slower. |
#5 | |
#6 |
Correct me if I'm wrong, but shooting at 60i is not 60 frames per second. It's 60 fields per second. Which means, when it's all said and done it's still only 30 frames per second. In order to really do this well you'll need a camera that can capture at least 60 full progressive frames per second.
And to piggy back off of Nick's comment, Apple's Shake has an amazing ability to interpret frames that don't exist and produce incredibly smooth slow motion. The interface is quite different than most, but once you learn it, it really makes more sense. Anyway, hope that helps... (?) |
#7 |
Tim, you're not wring as such, but The 2 fields in 60i video can each be mapped to a progressive frame to give you smooth 50% speed slow motion at 30p, but of course you'll lose vertical resolution, as you would with normal field doubling de-interlacing.
There's a good demo on the JES deinterlacer page in the difference of an iMovie slow mo (deinterlaces and then slows down to 15fps playback, looks jerky) and true field to frame slow mo (ie 60i gets turned into 30p field-to-frame, as smooth as film overcranking). JES does a pretty good job of adaptive pixel matching to get you SOME of the detail back. |
#8 |
But that would mean that I should be able to shoot at 30p and get slow motion? That doesn't really make much sense. I'll check out the article, and maybe I'm just missing something.
Thanks, Dylan. |
#9 | |
Shoot 60i and you can create 30p slow mo in post. |
#10 |
I get it. I'd be interested in seeing footage of this. Seems like the loss of resolution would be unbearable.
#11 |
Unlike John, my recommendation is to use your default shutter speed (1/50th here in PAL land) and interlace. Slowing down the footage by half means making every field into a frame, and with so little info to work with, don't up the shutter speed and delete information at source.
The Canopus Speed Control shows why it's important to shoot at the default shutter speed. With the CSC you can slow footage on a sine wave, going from normal speed gently down to a still frame, say. As the still frame is reached individual fields are blended together, and if they're 'sharp' (from using a high shutter speed) this blending just looks jerky. tom. |
