Thread Tools
Search this Thread
Software that shift fields of mpeg-2 clips?
I have used MPEG Streamclip 1.8 to convert mpeg-2 clips to DV25 but it doesn´t work when I have mpeg-2 clip that has wrong fieldorder ( I want lower fleld PAL)
Is there a software that shift fields of mpeg-2 clips for MAC? Kind regards Erik Palm |
Erik, Are you sure? I've converted many mpeg2 clips to DV25 and have always ended up with the correct field order provided I set it in the dialogue box. Which version of OSX/quicktime are you using? Also are you using Perian or Quicktime MPEG2 Component to get MPEG2 support?
If you can't get it to work, JESdeinterlacer (http://www.xs4all.nl/~jeschot/home.html#DEI) should do what you want |
