Best format for making stills from HDV frames in FCP
What would be the best format in FCP to create stills from HDV frames to burn a cd so a friend can then print them at a copy shop? PNG? JPEG? Photoshop?
I always export as Tiff, it's loss-less. Jpeg is re-compressing the frame. If you post-edit in photoshop then save it as a PSD.
*e |
PNG seems to be the format of choice for lossless (yet effective) compression of graphics. It is widely supported by other software. JPEG leaves compression artifacts, but can yield smaller file sizes than PNG. I'd go for PNG unless you have good reasons to use another format.
See this link for some information regarding PNG vs. TIFF: http://en.wikipedia.org/wiki/PNG#Comparison_with_TIFF - Martin
Martin Pauly |
Thanks for the info!
In the options window for PNG, are Best Depth and Best (for filter) the way to go or is Millions of colors or another a better choice. And when I open the frames in Photoshop they're always 4:3 and I change image size to reflect 16:9, should I be doing that another way. One problem with Photoshop is its Brightness/contrast filter doesn't do as good a job as FCP, oddly enough, but FCP's changes don't transfer to Photoshop. |
#5 | |
This will change the preview to the correct aspect ratio without actually changing the internal representation of the image. The result can sometimes look a little strange (poor quality) - at least in my CS2 copy of Photoshop - but this is purely the preview of non-square pixels on a display that has square pixels. Actually, now that I read your original post again, maybe I should take back what I just said. HDV pixel aspect ratio would be good if you intend to use the image for video in FCP, but it sounds like you are going the other way. So resizing is probably the way to go. - Martin
Martin Pauly |
