Help with Static Ridden Audio in FCE at DVinfo.net
Final Cut Suite
Old October 6th, 2007, 07:22 PM   #1
Attached is an audio clip from a project I'm working on. It's pretty static ridden. It was recorded quite a while ago, and I've improved my acquisition since, but I still need to use the clip - and a few others that have the same problem.
I don't have FCS - only FCE 2.02 and Garage Band 4.1
I was able to use a couple of different filters to reduce the static when she is not talking, but it is still too evident when she is talking. The filters I used so far are:
1. Expander/Noise Gate
Threshold: -30
Ratio: 1.77
Attack Time: 5
Release Time: 100
2. 3 Band Equalizer
Low Freq: 501
Low Gain: 12
Mid Freq: 1500
Mid Gain: 0
High Freq: 10000
High Gain: 0
3. Notch Filter
Freq: 8000
Q: 6
So where do I go from here? I'd like to refrain from a large expenditure right now, so shareware, freeware and free/low cost plugins are preferred. Any help would be appreciated.
And no, re-recording the interview isn't an option. I wish it were...
"... the drama is on your doorstep..." - John Grierson
www.grvideo.net
Kevin Randolph is offline   Reply With Quote
Old October 11th, 2007, 11:24 PM   #2
Bueller?...
Bueller?...
Bueller?...
Anybody?...
www.grvideo.net
Old October 12th, 2007, 02:54 AM   #3
Images: 18
Hi Kevin............
Just a thought, as on my system anyway (which is pretty good) that clip just sounds sort of "60's" for want of a better word. Why not tune the video to the clip and not the clip to the video.
Sounds like a shed load of audio taken off 60's & 70's doco's, most people (I refer to normal, non video people) wouldn't bat an eyelid if that was on a doco.
Otherwise can't be of much help.
CS
Chris Soucy is online now   Reply
