changing duration to jPegs at DVinfo.net
Final Cut Suite
Old October 2nd, 2007, 03:04 PM   #1
I have about 100,000 jpegs.
I am making a time-lapse from webcams.
The default duration of the jpegs is 10 seconds.
How can I change the duration to 1 frame to all pix at the same time?
thx
Gary Chavez is offline   Reply With Quote
Old October 3rd, 2007, 09:15 AM   #2
You have to do that in the preferences BEFORE you import your jpegs.
User preferences>editing>still freeze frame duration, then import.
Also for what you are doing, you should know about the "paste attributes". If you change the scale or even add a filter to one jpeg in the timeline, you can copy it, then select all the others and edit>paste attributes then you can make changes to all your pics at once.
Aric Mannion is offline   Reply With Quote
Old October 3rd, 2007, 07:17 PM   #3
In Quicktime Pro, you can load a folder of sequential jpegs and automatically create a movie. You can set a number of different frame rates.
Much easier than trying to do it in Final Cut.
Chuck Fadely is offline   Reply With Quote
Old October 3rd, 2007, 08:10 PM   #4
Indeed. File > Open Image Sequence.... Then choose correct framerate, which you could later easily adjust in FCP. I'd suggest just going with 29.97 [or 23.96] in QT. File > Save as...; and check self-contained.
Daniel Ross is offline   Reply With Quote
Old October 4th, 2007, 03:17 PM   #5
Hey Guy,
The replies went to the junk folder.
Thanks for the tips.
After thinking about it, I came up with Aric's way.
turned out to be 175,000 pix.
Thankful the webcam software (Stardot technologies)
captures sequentially so no problem there.
Also, I changed my output encode to "photo-jpeg."
that saved 10 hours of render vs the DV-NTSC encode.
Old October 7th, 2007, 11:38 AM   #6
For future reference...
Lay all images out in your timeline.
1 of 2 ways to change duration..
1. Select all images, right click, select Duration, change the time in the box, hit enter twice. (once to initiate, second to close the box.
2 If that does not work, do the same to one clip without any transitions. Then select that clip then Command C to Copy, then select all other clips, and Option V to paste attributes, select the proper check box and your good to go.
Jim Fields is offline   Reply
