Field Dominance Problem with XH-A1 DV 25p and FCP6 at DVinfo.net
Final Cut Suite
Old September 19th, 2007, 08:33 AM   #1
Hi,
Ive been around the block with this a few times and am still not sure where im going wrong.
Im Filming in 25p on My XH-A1 - capturing through Capture Magic SD
When I put the footage into FCP its reading it as field dominance Lower (even)
I initially though that i had just messed up when filming and recorded in 50i, however after reading a round i interoperated footage in After Effects which also tagged it as lower but it still looked interlaced. (I also checked my camera which is still set to 25p)
when i set field dominance off in after effects it looks perfect.
I'm guessing that my capture software has tagged the files as Lower instead of none??
When I put the footage in FCP and set field dominance to lower in the sequence settings it looks fine which would be great if i wasn't mixing it with footage from screen capture software which is progressive footage.. (the main reason for getting a 25p camera)
Is there any way to solve this problem? possibly a way to tag the footage as progressive as opposed to interlaced (lower)?
I have tried de-interlace plugin in FCP but it dosn't help at all
R. Phil Johnston is offline   Reply With Quote
Old September 19th, 2007, 09:05 AM   #2
Sorted!! Yay!!
Got it sorted!! Quite simple really..
Right (Ctrl) click on the clip and go in to item properties/format.
from there you can right click on the field dominance and set it to either - none, upper(odd), lower(even) or not set.
Im guessing you all already knew this! Doh!!
