Dual Layer in DVD Stdio Pro at DVinfo.net
Final Cut Suite
Old September 12th, 2007, 02:25 AM   #1
I need to put six half hour episodes of a series across a dual layer DVD, all accessed via a main menu. The DSP manual refers to a break point where the DVD player switches from reading one layer to the other. HOWEVER the manual assumes my content is one long continuous file - i.e. a movie.
What I want to do is have three tracks on one layer and three on the other, or four on one and two on the other. Therefore a break point seems to be a bit of a tricky one to set, I don't want it in the middle of an episode because it causes a slight pause in the footage. Does anyone have any ideas how I should set this up?
Daniel Stevenson is offline   Reply With Quote
Old September 12th, 2007, 07:11 AM   #2
You could add a few seconds of black slug to the last frame of episode three and mark the break point there? I'm presuming credits will have just finished there, and the viewer(s) will have shifted their attention from what's going on on-screen.
Do you absolutely have to use DL? They can be problematic with some DVD players. Just a thought.
Sean Kiely is offline   Reply With Quote
Old September 12th, 2007, 09:39 AM   #3
Go Go Godzilla
Images: 15
Sean is correct; dual-layer discs that are burned rather than imaged from a replicator tend to be problematic on playback with various players. If possible you'd be better off using a 2-disc distribution on DVD-5 rather than DVD-9 (dual layer) and you'll avoid *most* incompatibility issues.
Old September 12th, 2007, 10:45 AM   #4
If you break your project into separate timelines in FCP (pending they are short videos) and export each video separate, you can then open DVDSP and drop each one into it's own track. Once done, if you only want 1 link on the menu then you can connect the end of each video to the beginning of the next, so on and so on, then if you you decide to do Dual Layer, you wont have as much of an issue with the break point, as you will have a better chance of that break point being between video tracks, and not on a video track.
you could also place a marker at the end of one of the videos and tell DVDSP to do the jump to the second layer at that marker.
I love DVDSP, it has to be one of my, if not my favorite program out there.
Jim Fields is offline   Reply With Quote
Old September 12th, 2007, 06:07 PM   #5
Yeh i like dsp too Jim, I'm not sure I use it to its full potential but it has served me well!
thanks guys, i'll see how it goes.
Old September 27th, 2007, 09:24 PM   #6
Just an update, yep as was flagged, the dual layer option in DSP didn't go down well in our DVD player so went fpr 2 DVDs instead.
Thanks for your help!
