best compression settings under 10mb? at DVinfo.net
Final Cut Suite
Old August 29th, 2007, 10:18 AM   #1
Hi,
I was wondering if anyone had a suggestion fir getting a pal SD clip of 4 minutes under 10 mb so I can send it via regular email? Everything i try is either too big, or too poor quality. Is just for preview so doesn't need to be super sharp, but should be watchable...
Tips?
Tom Rosson is offline   Reply With Quote
Old August 29th, 2007, 03:28 PM   #2
Kino-Eye
The best quality for a specific size you're going to find is using the H.264 codec, but getting 4 minutes down to 10MB is a tall order, so you're going to have to make some sacrifices in terms of quality, resolution (frame size), and frame-rate.
David Tames { blog: http://Kino-Eye.com twitter: @cinemakinoeye }
David Tamés is offline   Reply With Quote
Old August 29th, 2007, 05:11 PM   #3
h.264 is the way to go for video. I would start by cutting the frame rate in half, make the video small, and then work on the bit rate. Also don't forget to cut the audio quality too. Just going to mono will help a lot in hitting your target.
But at the end of the day, you probably wont be happy with the quality at 10mb. I've been able to get 3 mins down to about 6mb using the above formula, but its nothing like full screen HD - or SD for that matter.
Patrick Pike is offline   Reply
