Fade in at DVinfo.net
Final Cut Suite
Old August 12th, 2007, 04:56 PM   #1
Fade in
problem solved
Luke Raymond is offline   Reply With Quote
Old August 12th, 2007, 05:39 PM   #2
While I can't give you the specifics for the software you're using, the approach I'd take is this:
Start with a cross-dissolve from a black still to the footage you want to fade to. Then, on a track above the cross-dissolve, do a zoom-in on a black frame with a transparent circular opening (easy to do in Photoshop) to where the transparent opening gets larger as the cross-dissolve progresses, so the transparent opening progressively reveals more of the cross-dissolving footage. Jack with the blur settings and opacity on the circular frame track so you don't get a sharp edge to the transparent opening as it gets larger.
Regards;
Martin
Canon XF300, Canon 5DMkII, Canon XL2, Rolls MX422 mixer, Zoom H4N, AT899 lavs, AT2020's, Azden SGM 1X shotgun, Manfrotto 501 head on 351 tripod
Martin Catt is offline   Reply With Quote
Old August 12th, 2007, 05:55 PM   #3
In FCP use an "Oval Iris"
Effects > Video Transitions > Iris > Oval Iris
The default is round.
Click Feather Edges and slide the Border control to increase the softness.
I know it's tempting to just ask here - particularly when you're in a hurry or need help quickly - but it's also nice to honor the immense amount of work that the the FCP team put into the physical manuals that come with the program. There are sections on Transition, Wipe, etc. Lots of extremely useful info there.
Old August 12th, 2007, 06:22 PM   #4
Thanks martin. Problem solved.
