25p capture delay on new mac and STUDIO 2 at DVinfo.net
Final Cut Suite
Old July 31st, 2007, 06:12 AM   #1
Hi its doing my head in, all i want to do is captur my footage and it seems to miss whole clips! JVC gy-hd111e 720p 25p
i shoot a lot of action and sometimes these clips are short.
i tried the AIC but it converts footage into 50p or something.
how can i capture all my clips with out missing so much????
if anyone has any ideas......
Mick Wilcomes is offline   Reply With Quote
Old July 31st, 2007, 03:41 PM   #2
Hi Mick.
You could change the capture settings/preferences in FCP to minimize the amount of pre-roll needed.
But if that doesn't do the trick, there is a foolproof method which will capture every single frame recorded on your tape (the DVHSCap-MPEG Streamclip workaround).
I've given the complete steps for it in this post:
http://www.dvinfo.net/conf/showpost....53&postcount=8
I've given that example using the AIC codec, but you could also use ProRes (as you have FCS2).
Good luck.
David Knaggs is offline   Reply With Quote
Old August 4th, 2007, 06:33 AM   #3
thanks
Originally Posted by David Knaggs View Post
Hi Mick.
Good luck.
thanks alot for your time mate, mick
