Neat video vs Davinci anti-noise filter at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old October 15th, 2018, 11:48 AM   #1
Hello, I am working in Final Cut Pro and have some scenes with heavy digital noise.
My colorist is using Davinci and is trying to remove noise using Davinci's own noise filter.
I think the results are very moderate.
I am now looking at a trial of Neat Video's filter and it looks better at a first look but I am not still convinced if it's worth the USD 100.
Has anyone tried both (or any other filter you recommend) and can tell of your experience?
Urban Skargren is offline   Reply With Quote
Old October 17th, 2018, 08:42 PM   #2
Re: Neat video vs Davinci anti-noise filter
I have both DaVinci Resolve Studio and Neat Video. Resolve's NR is great with the right tweaking and very fast. Neat Video is slow, but I find the overall results to be better. I have purchased Neat Video to use in both DaVinci Resolve and Final Cut Pro X, and actually used Neat Video in Adobe Premiere for some shots in a promo video I did for a business event in Medellín!
Old October 19th, 2018, 10:32 AM   #3
No experience with Resolve but Neat has worked well on old VHS footage for me. SLOWWWW, however.
Old October 22nd, 2018, 11:23 AM   #4
For those using recent a version of Neat Video, on a decent workstation such as Intel Core i7 with nVidia graphics, make sure to check out the tuning/optimization offered in the app. I forget offhand exactly what it is called, but look and you will find it. It checks the system hardware to determine the optimum combination of CPU cores and graphics card usage to get the fastest results and you can then select the best combination for it to use and that really speeds up the renders.
Jeff
Jeff Pulera
Safe Harbor Computers
Old November 22nd, 2018, 11:19 PM   #5
Has anyone tried the video noise reduction in FCPX 10.4.4? And compared it to Davinci and Neat Video?
Charles W. Hull is offline   Reply With Quote
Old November 26th, 2018, 01:41 PM   #6
And by chance I happened to be testing all three a couple of weeks ago on some SD BetaCamSP footage, animation and live action. The goal was to create the best up-res to progressive HD of the footage. At first I was comparing Neat and Resolve and then suddenly FCPX was updated to include it's own noise reduction filter. I found the results very dependent on the footage. I have not had a chance to try these programs on HD video yet.
- The Resolve "Supersize" option in the file attributes dialog box did the best job of reducing tape/camera noise (not tape dropout) and returning a surprising amount of detail to faces. You could be tricked into thinking the original was shot on 16mm. The colors in drawn animation looked great with all noise in colors flattened without looking posterized. For this footage adding the Resolve noise filter did not improve the footage much, the SuperSize filter did a better job on SD footage even with the six limited, preset options in the filter. The Supersize filter does not seem to do anything to HD footage on an HD timeline. Rendering is reasonably fast. Deinterlacing was fair.
- Neat was very good with the animation with more options to adjust the parameters as far as my experience with Resolve goes. I accept my temporary ignorance if I am missing a feature in Resolve. The problem initially before the FCPX update was that deinterlacing in FCPX softened the image where a certain amount of detail was not retrievable without making the footage look weird in HD. The live action footage looked good but it was a tossup if the time taken to render it was worth it.
- The new FCPX noise filter is curiously very similar to the Resolve Supersize filter in operation (only six preset options in two sets of three). And just like the Supersize filter, it does a very good job with the SD footage I threw at it. Not as good but close. VERY SLOW to render on my particular computer, a 2013 MacPro, but I have heard it's faster than Neat on a more modern Mac.
By far, the FCPX de-interlace filter does the best job of removing interlace jitter and aliasing. The animation I was up-resing needed that badly for HD and one live action interview from 1991, the subject was wearing a horizontally striped shirt which neither Neat or Resolve could stop pulsating. Unfortunately it's either on or off in FCPX, no adjustments like in Resolve.
After rendering different test combos I made the judgment that using the new FCPX noise reducer with the FCPX deinterlace option was the best choice for the animation even though I lost a little clarity over the Resolve result. The live action is a long term project and a final choice will be down the line. I might run footage where the interlacing isn't a problem thru Resolve and the rest in FCPX, a decision for later.
Old November 26th, 2018, 11:23 PM   #7
It's "Super Scale" in the Clip Attributes option, not "Supersize".
Old November 29th, 2018, 10:40 PM   #8
Indeed it is called that.
William Hohauser is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
