Exporting from Davinci to Final Cut Pro X (in ProRes) at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old June 20th, 2018, 06:44 PM   #1
Hi all,
I am finishing a short film project, I have edited in Final Cut Pro X (latest version) and a friend graded the film in Davinci Resolve on a PC. The film is natively shot on 4K ProRes 422HQ. However, we discovered that there is no ProRes export option in Davinci on PC, so my friend exported in DNXHD 4K, he says that is what corresponds to ProRes. But now that I have the exported files on my Macbook Pro, none of them open in FCPX neither in Quicktime Player. They open (with a lag) in VLC, but not in Compressor nor Mpeg Streamclip.
Does anybody here know how we can export in ProRes from Davinci or losslessly batch convert the files to ProRes on my Mac? Or can I somehow install the DNXHD codec on my computer and make the files readable?
Urban Skargren is offline   Reply With Quote
Old June 21st, 2018, 03:16 PM   #2
Re: Exporting from Davinci to Final Cut Pro X (in ProRes)
Hi again. I was able to import the clips using this codec package:
Avid QuickTime Codecs LE
But they play back as green screen (only green on image) and also export like this. Don't know what to do...
Old June 21st, 2018, 04:58 PM   #3
Originally Posted by Urban Skargren View Post
Hi all,
You could use ffmpeg to generate non-official ProRes like code.
Cary Knoop is offline   Reply With Quote
Old June 21st, 2018, 05:04 PM   #4
Would there be any quality difference?
Old June 22nd, 2018, 02:36 PM   #5
First off, QuickTime Player sometimes can't play advanced professional codecs that FCPX can. Try using FCPX.
Second see if a program like EditReady can convert the files to ProRes.
Third, see if your friend can export to Cineform which FCPX does read.
Fourth and last: Export either a TIFF sequence or JPEG2000 sequence from Resolve and import that into QuickTime Player or Compressor and create a ProRes file from that. You will have to import the audio track separately.
William Hohauser is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
