FCPX blows exposure and highlights at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old December 7th, 2016, 12:32 AM   #1
I was about to start editing a project. Thought let me update the FCPX before a project.
I opened the files and suddenly see that my files are blown by more than a stop. All highlights are blown. After shooting last month, I had imported sample files and they were fine. I had monitored while shooting as well. Suddenly, everything looks like an amateur exposure mistake. I always shoot in c-log (using a Canon C300) and the footage is fine when viewed in Canon XF Utility. Has anyone faced such a problem? Is FCP applying somekind of LUT or something?
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old December 7th, 2016, 11:12 AM   #2
Re: FCPX blows exposure and highlights
It's not applying a LUT from your description. You should reapply the LUT in the Settings menu in the info inspector.
Old December 29th, 2016, 01:20 AM   #3
Thanks William!
I found that FCPx has an option to switch off the c-log conversion. And it worked.
I expose the c-log files a bit differently then everyone else. So it was a problem for me. Nevertheless, it is sorted out now.
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
