Placeholder with linked assets... at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old September 14th, 2016, 05:30 AM   #1
Hi to all :)
Can someone help me to achieve this-
I have hundreds of 3-4min projects.
All with the same-
10 sec intro,
overlay burner over the body of the project,
and a 10 sec outro.
I can set it up with a placeholder in between the intro and outro and have the overlay attached to the intro.
Thats fine. I just drop each file on the placeholder and select Replace.
The problem is, the overlay has to be manually adjusted each time to length.
Is there a way to link the overlay length to the placeholder so it always becomes the length of the inserted file?
http://vimeo.com/livewebvideo
Gerald Webb is offline   Reply With Quote
Old September 14th, 2016, 01:02 PM   #2
Re: Placeholder with linked assets...
None that I know of. It's easy enough to use "option ]" to shorten the overlay after you replace the placeholder, although with the number you have to do, daunting,
Old September 15th, 2016, 02:29 PM   #3
Thanks for responding William.
I'll keep looking
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
