Importing files from FS5 at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old August 26th, 2016, 11:13 AM   #1
Hi all,
I imported some 4k footage (shot on an FS5). I realize that the same clips are appearing twice. For example:
Clip0001 is appearing in "XDCAM FORMAT PLUGIN" and "Quicktime Movie".
I revealed the file and realized that the files under "XDCAM FORMAT PLUGIN" are all MXFs and "Quicktime Movie" are all MOV (which I believe FCPX renamed the mxf to mov?)
In attempt in trying to keep the library smaller, may I delete all the duplicates from either "XDCAM FORMAT PLUGIN" or "QUICKTIME MOVIE"? Just want to find out what would happen if I delete the duplicates.
Aaron
Aaron Leung is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
