Rendering After Every Edit at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old April 14th, 2016, 08:50 AM   #1
Is this normal for FCPX? Even if I make the smallest adjustment, the video has to render.
Just FYI, I'm running on an i5 iMac with 24GB of RAM and have all my media stored on a thunderbolt external drive.
Brock Burwell is offline   Reply With Quote
Old April 14th, 2016, 09:19 AM   #2
Re: Rendering After Every Edit
You can turn this off, if you wish, or change the timings in Preferences for FCP X under the Playback heading.
Kevin Langdon is offline   Reply With Quote
Old April 16th, 2016, 12:11 PM   #3
If you have added filters or done anything to alter the original video, then yes, FCPX will want to render again. Video that is not altered, just dropped on a similar format timeline (size/frame rate), will not need rendering except with transitions.
William Hohauser is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
