Project Disappeared at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old April 12th, 2016, 08:44 AM   #1
Project Disappeared
When I got into work today, I noticed that a project that I had been working on had disappeared. It'd odd because the event is still there, but the purple box with the star in the middle of it is no longer beside the event name. When I click on the event, it takes me to an empty project.
I went into finder to see if that would fix it, but when I try to open the event from the finder, FCP crashes as soon as it opens. I tried it with different events as well and it does the same thing.
Any suggestions?
Brock Burwell is offline   Reply With Quote
Old April 12th, 2016, 09:55 AM   #2
Re: Project Disappeared
FCPX creates backups in a folder you specify. Probably under your "Movies" folder. Check there and open the most recent version.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old April 12th, 2016, 10:00 AM   #3
OK so I went into my Movie folder and then Final Cut Backups and there are two folders there. I currently have three Libraries but only two Libraries are showing in that folder. Any idea why?
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
