Slomotion to Normal Speed - Sony FS5 (240 fps) at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old January 21st, 2016, 08:33 AM   #1
Hey just wondering how to go from slow to regular motion in a single shot. I have just bought the Sony FS5 which does slomotion, but unsure how I'd then return to regular speed in the shot.
I presume it's something that's done in the edit.
Any help gratefully appreciated!
Dave Mercer is offline   Reply With Quote
Old January 21st, 2016, 11:33 AM   #2
Re: Slomotion to Normal Speed - Sony FS5 (240 fps)
Yep, in post Dave.
Old January 21st, 2016, 12:36 PM   #3
Thanks Andy. So record at 120 fps or whatever, drop onto a timeline in FCP 10, then retime? Image when slowed to normal speed doesn't look weird?
Old January 21st, 2016, 02:19 PM   #4
I have FCP6 and FCPX... but only really edit in CC2014 (or CS6) now depending on which Mac Pro I am using.
On CC, with the clip in a 1080p25 timeline you can just chop the slomo clip where you want to make the speed change and re-time/change speed percentage to whatever you want for either section(s). In Cambridge/not in my studio in front of my edit systems but that's how I remember it...
Old January 21st, 2016, 06:20 PM   #5
Hi Dave,
No, as you suggest just drop the high speed footage into a timeline - say 30fps, and FCPX will retime by missing out frames. If you want to make it slow motion go to retime menu and Automatic speed ( used to be conform) this will slow it down. You can add custom speeds or speed ramps as needed.
There is some useful information from Alex Gollner over at http://alex4d.com/notes
Paul Wood is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
