Best PPCC Capture Settings on a PC to edit in FCP on a Mac? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old June 3rd, 2015, 05:32 PM   #1
A friend gave me 6 hours of old Mini-DV tapes that he wants to edit on his Mac (he has no Mini-DV player/recorder). He also gave me a 2 terabyte hard drive to transfer these files to, once they are captured. I have a PC with Premiere Pro CC. What format and codec should I capture these tapes in that will be best for him to edit his footage? I don't work with macs so I'm fairly ignorant about their video codec needs.
Any help is appreciated. Thanks. :-)
William N Zarvis is offline   Reply With Quote
Old June 5th, 2015, 10:03 AM   #2
Re: Best PPCC Capture Settings on a PC to edit in FCP on a Mac?
Unless you can download the Quicktime ProRes codec for PC, which quite frankly I don't know if it enables capture, you can capture in the standard Premier DV codec. He will be able to play these files or convert them to QuickTime.
Old June 5th, 2015, 12:44 PM   #3
Capture as dv on the pc. He can import as is.
Old June 6th, 2015, 10:00 AM   #4
Thanks guys! That's what I'll do!
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
