Insert Editing, Why Won't Clips Appear In The Timeline? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old January 29th, 2015, 05:47 AM   #1
I have FCPX 10.1.4
Every time I attempt an insert edit the clip appears under the Timeline in a Secondary Storyline I guess, with a gap in the Timeline of exactly the same length as the inserted clip.
I want all inserts into the Timeline, I do not want a Secondary, or Tertiary Storyline. Similarly I want to drag clips from one part of the Timeline to another without any activity on a Storyline.
I am indifferent to the length of the project by the way.
Any suggestions as to what I am doing wrong will be appreciated.
Ron
Ronald Jackson is offline   Reply With Quote
Old January 29th, 2015, 06:52 PM   #2
Re: Insert Editing, Why Won't Clips Appear In The Timeline?
How are you inserting the clips? I just type "W" and it goes in the primary timeline.
Old January 30th, 2015, 02:27 AM   #3
I use the insert edit "downward arrow" but the same problem occurs if I use "W".
Ron
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
