chapter markers missing at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old July 22nd, 2014, 05:19 AM   #1
burning dvd of dance recital, adding chapter markers and they don't show up on dvd when played. Seems like I had this problem on macbook pro with external drive but not when burning to internal drive. This project on mac mini with external burner, any thoughts? I've done this before with no problems
Charlie Branham is offline   Reply With Quote
Old July 22nd, 2014, 01:35 PM   #2
Re: chapter markers missing
Where are you placing the markers? And are you making sure that they are chapter markers as opposed to standard markers? Are you exporting directly to DVD or making a master file first with "include chapter markers" checked?
Old July 22nd, 2014, 07:46 PM   #3
I actually did both. I did do the chapter markers and on second try went to master file with chapter markers and dropped into toast to burn with no menu. The master file has the chapters, but not on the disc.
Old July 22nd, 2014, 08:14 PM   #4
Toast may not recognize the chapter markers. Compressor and DVD Studio Pro will. Maybe Encore also.
Old July 23rd, 2014, 05:54 AM   #5
I am encoding with compressor now, the chapter markers are visible in the display in compressor. Once apple changed the work flow with final cut pro x I would just go directly to share from the timeline. Maybe this is a better solution with chapters but I just finished 2 projects that way and they worked. Still have a funny feeling it is something to do with an external burner, makes no sense. Thanks for your help.
Old July 23rd, 2014, 06:59 AM   #6
Toast does recognize chapter markers from FCP. Set the general Video Preferences to Chapter Markers: None but set the individual tracks to Chapter Markers: Automatic.
Fred Tims is offline   Reply With Quote
Old July 23rd, 2014, 09:24 AM   #7
in final cut pro? Or in compressor?
Old July 26th, 2014, 05:48 AM   #8
moved project to new computer, cut down on info on chapter marker (Content), exported to internal drive, worked perfect.
Old July 31st, 2014, 06:12 AM   #9
Finally took clip with many cuts and markers converted to compound clip and put chapter markers back , works perfect. Exports to dvd with chapter markers
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
