FCP 10.1.2 Update now available (along with Motion & Compressor updates) at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old June 27th, 2014, 01:40 PM   #1
Final Cut Pro 10.1.2
  • Optimized, proxy, and rendered media can be stored at any location outside of the library
  • Easily delete optimized, proxy, and rendered media from within Final Cut Pro X
  • Used media indicators for Compound clips, Multicam clips, and Synced clips
  • Option to show only unused media in the Browser
  • Apply a standard (Rec. 709) look in real time to high dynamic range and wide color gamut video from ARRI, Blackmagic Design, Canon, and Sony cameras
  • Automatically apply an ARRI embedded 3D LUT from the new AMIRA camera
  • Support for Apple ProRes 4444 XQ
  • Improved speed and accuracy when synchronizing clips
  • Audio recording improvements including countdown and automatic Audition creation from multiple takes
  • Fast export of cuts-only projects containing XDCAM media
  • Export entire library as a single XML file
  • Selecting a library displays key metadata in the Inspector
  • Adjust relative and absolute volume of a clip or range selection
  • Create Keywords from Finder Tags when importing media
  • Option to sort events by date or name in the Libraries list
  • Import a clip by dragging directly into the Browser
  • Share 4K video to Vimeo
2.28GB
Motion 5.1.1
  • Improved Sequence Text behavior for animating characters, words, and lines
  • Enhanced Contrast filter parameters for refined adjustments
1.63GB
Compressor 4.1.2
  • Better performance when working with large batches
  • Status display and improved responsiveness when using “Send to Compressor” from Final Cut Pro X and Motion
  • Improved performance and color accuracy when encoding H.264 source files from GoPro cameras
  • Fixes issues transcoding alpha channels in image sequences
  • Includes general stability improvements
318MB
Tim Dashwood
Old June 27th, 2014, 03:22 PM   #2
Re: FCP 10.1.2 Update now available (along with Motion & Compressor updates)
What is ProRes 4444 XQ exactly? Is it an RGBS version of ProRes 4444? I assume XQ stands for excellent quality ;)
David Parks: DP/Editor: Jacobs Aerospace at NASA Johnson Space Center
https://www.youtube.com/user/JacobsESCG
David Parks is offline   Reply With Quote
Old June 27th, 2014, 06:51 PM   #3
XQ is a very high data rate format that also exports with an alpha channel like ProRes 4444.
It's designed to work with 4K media in creating cinema ready video production.
Classroom editing instructor? Check out www.starteditingnow.com
Turnkey editor training content including licensed training footage for classroom use.
Old June 30th, 2014, 07:36 AM   #4
How fast is the data rate? It would seem logical that this new ProRes codec would be an upgrade for 4k outboard recorders like the Atomos Samarai.
Old June 30th, 2014, 04:40 PM   #5
An hour is over 225Gbs.
William Hohauser is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
