Best External Drives For 4K Editing? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old March 29th, 2014, 03:56 AM   #1
I need a couple of additional External Drives for my new iMac. Thinking ahead about the possibility of future 4K editing, is there anything in particular I should be looking for in external drives?
I favour G-Tech Thunderbolt/USB 3.0 drives, perhaps a piar of 3TBs.
Is there any "special" requirement in a drive for 4K editing. Capacity and T'Bolt I could see as a necessity but anything else?
Ron
Ronald Jackson is offline   Reply With Quote
Old March 31st, 2014, 12:45 PM   #2
Re: Best External Drives For 4K Editing?
Don't worry much about it. Any drive with a Thunderbolt interface is built on the basic idea that the user wants the best sustained data rate output the platform can provide - so there shouldn't be a problem.
Remember, the way that FCP-X is designed, you're able to create pools of media with different encodings and different data rates and switch between them rapidly and easily - so you can bring in full rez 4k, for example - let X transcode to a ProRes version for editing efficiency and performance, and both during and after you make your editing decisions in one mode, you can simply swap the internal pointers from the ProRes copies to the original media to check quality, do color correction and export masters.
This is one of the things that makes X great.
Classroom editing instructor? Check out www.starteditingnow.com
Turnkey editor training content including licensed training footage for classroom use.
Bill Davis is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
