Wavy Flashback Transition at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old August 20th, 2013, 08:42 AM   #1
I am looking for the classic wavy flashback transition. I found Alex4D templates (Alex Gollner -- lots of free stuff!) and the circular one is ok but I really wanted the transition that the old sitcoms used where the image went all wavy. Short of learning how to do this myself in Motion, any pointers? Alex4D had one for FCP7 but I didn't find one for FCPX.
Chip
*** http://www.vimeo.com/chipgallo ***
Chip Gallo is offline   Reply With Quote
Old August 25th, 2013, 03:26 PM   #2
Re: Wavy Flashback Transition
You mean a "pond ripple" transition?
Post production is not an afterthought!
www.arniepix.com
Arnie Schlissel is offline   Reply With Quote
Old August 25th, 2013, 04:48 PM   #3
What I had in mind was wavy, top-to-bottom lines. I have a circular wavy pattern (with the center of the circle being fairly undistorted) but the flashbacks I remember from 1960's and '70's sitcoms were vertical waviness. Not sure about pond-like ripples but probably not.
Old August 27th, 2013, 10:03 AM   #4
Using a displacement map of a cascade/sheet of shallow water running down a surface combined with a progressive/keyframed blur and crossfade would probably do the trick. Several layer and not automagical, but it'd get the look pretty close.
designer of media for eyes and ears
sound design and field recording at http://www.noisejockey.net/blog
Nathan Moody is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
