Compound clip changes globally
Hello I stumbled on a problem. I have a project with a compound clip. Then I duplicated the project to do another version of it, but I discovered that if I change anything in the compound clip within that project, it changes in the other project as well. How can I avoid this?
Thank you. |
Re: Compound clip changes globally
Open the compound clip, select all the clips and copy. Paste the clips into your new project and then make the changes. You can create a new compound clip first if that helps with organization.
William Hohauser - New York City Producer/Edit/Camera/Animation |
Thank you.
Here's a tutorial I put together on this...
Tutorial: Using Compound Clips in Apple Final Cut Pro X - Streaming Media Producer |
#5 |
This is something that started at FCPX 10.0.6.
Every compound clip used to be independent. Now it's one global clip, that's automatically added to your Event (this also didn't used to be the case) where if you make a change to the original, it ripples trough. You can make a compound clip independent in the Event, it's somewhere in the Menu. MacBreak Studio also has some tutorials about it, I think. |
#6 |
Thanks Glen! Great tutorial.
I also found some basic info on this page: http://support.apple.com/kb/PH12630 There I learned that I can make a snapshot of the project, which makes new, independent compound clips for all of my project. Then I can rename the new compound clips if necessary. Do you see any cons to this solution? Last edited by Urban Skargren; October 2nd, 2014 at 09:25 AM. |
#7 |
Also do a search on "FCP X reference new parent clip" - it's a menu selection that breaks the relationship between the compound clip and it's parent clip in the Event when that's what you need to do.
Classroom editing instructor? Check out www.starteditingnow.com Turnkey editor training content including licensed training footage for classroom use. |
#8 |
Yes, I am now familiar with these terms and this helped me a lot. Thanks!
