25p to 24p at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old May 14th, 2013, 08:14 AM   #1
25p to 24p
My Sony FS700 camera was in the PAL region setting… and I accidentally recorded 1080p at 25fps rather than 24fps. (the codec is AVCHD)
I need to convert the footage to 24p.
In the past I've used hardware at a lab, but I shot this for free and I'm paying for the conversion.
I don't want to compromise the quality, but I liked to spend as little as possible.
Any suggestions?
______________________
Bill Kerrigan
Montreal, Quebec, Canada
http://www.kerrigan.ca
Bill Kerrigan is offline   Reply With Quote
Old May 14th, 2013, 08:25 AM   #2
Re: 25p to 24p
Are you going to do the editing yourself? If so what software will you use? Most will allow you to mix frame rates and you will never know in the final product.
If you aren't going to edit it you can still use your editing software to do the conversion.
http://www.LandYachtMedia.com
Old May 14th, 2013, 09:03 AM   #3
Re: 25p to 24p
Usually 25p is time-stretched into 24p for a one on one frame transfer. The sound is changed and you might need to shift the pitch slightly if you have music on the footage. You can use a conversion program like Compressor. In Compressor you will have to make a custom setting where you specify that you want one-on-one frame conversion otherwise the program will blend frames. If you don't care about blended frames, such as with a seated interview, FCPX does a very good job of frame rate conversion.
Old May 14th, 2013, 09:14 AM   #4
Re: 25p to 24p
FYI Bill,
Its best to post a question in a single part of the forum. It gets confusing when the same thing is asked in multiple locations.
Old May 14th, 2013, 01:08 PM   #5
Re: 25p to 24p
Depending on what you're editing software is, you can just drop the footage in a 24 track and edit without any problems. I haven't done this myself with 25p but I dont think you would be able to see any difference, I usually do it with 60p though.
James Barbosa is offline   Reply With Quote
Old May 14th, 2013, 03:46 PM   #6
Re: 25p to 24p
Duplicate threads merged...
Old May 14th, 2013, 11:53 PM   #7
Re: 25p to 24p
I have mixed 24p shots and 25p shots. Nothing to worry about. Put all those in FCP X timeline and export to 24p.
In FCP X, when you start a project depending on the first clip it can set the frame rate of 25p or 24 p. Or you can set it on your own.
I haven't done this mixing with narrative. However, I have done it with wildlife shots. I am sharing a link here. The first three mins is shot in C300 at 25p. The next is at 24p with a Canon DSLR (1D Mark IV). The final output is exported at 25p.
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old May 15th, 2013, 03:39 PM   #8
Re: 25p to 24p
Brilliant...
Thank you all for the help.
Best,
Bill
Bill Kerrigan
DOP, director, teacher
Old May 15th, 2013, 07:16 PM   #9
Re: 25p to 24p
Another easy way to do this is right in FCPX:
Say you have a 25p clip in a 24p timeline. Just click on/highlight the 25p clip and then go to the retiming options (the little stopwatch icon on the middle right of the final cut interface). Select "Conform Speed" and the program will stretch out your non-standard clip to match the project settings. Handy if the motion is non-descript and doesn't have any speech.
This is also very convenient when you're shooting 30p or 60p and want slow-mo in a 24p timeline without any frame blending or "close enough" manual time stretching. Conform speed spaces out the frames in the source footage to match the project timebase. Done.
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old May 16th, 2013, 03:16 AM   #10
Re: 25p to 24p
Excellent. Didn't know that was in there.
William Hohauser is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
