Thread Tools
Search this Thread
FCPX 10.0.8 is out!
What's New in Version 10.0.8
- Support for Sony XAVC codec up to 4K resolution - Option to display ProRes Log C files from ARRI ALEXA cameras with standard Rec. 709 color and contrast levels - Resolves an issue where some third-party effects generated green frames during render - Resolves performance issues that could occur with certain titles and effects - Time reversed clips render in the background - Ability to use key commands to adjust Clip Appearance settings in the timeline - Ability to view reel number metadata located in the timecode track of video files - Mono audio files in a surround project export with correct volume levels - Drop zones no longer reset to the first frame of video after application restart - Fixes a performance issue which resulted from selecting multiple ranges on a single clip - Fixes an issue where the Play Around function did not work properly on certain clips when viewed through external video devices Also out are new versions of Motion and Compressor... |
Re: FCPX 10.0.8 is out!
"Now, after updating the software seven times since its release in 2011, Apple is launching a campaign Thursday aimed at winning back skeptical professional users.
That campaign, timed to coincide with the National Assn. of Broadcasters convention that starts April 6 in Las Vegas, will feature users like Julian Liurette, who followed the firestorm from his video editing desk in Toronto at the Globe and Mail newspaper. After waiting a year as Apple gradually released updates, Liurette finally gave it a try and was surprised. So Liurette began moving the newspaper's video operations from the old version to Final Cut Pro X. The campaign will also feature Hong Kong cinema icon Tsui Hark and Mexican television conglomerate TV Azteca." (Apple Launching New Final Cut Pro X Marketing Push to Win Back Professionals - Mac Rumors)
"The good thing about science is that it's true whether you believe it or not." Neil deGrasse Tyson https://www.nautilusproductions.com/ Last edited by Rick L. Allen; March 28th, 2013 at 07:07 PM. |
I hope this update fixes the green frame rendering problem right across the boards and not just with 3rd party effects. I'll update and see.
#4 | |
- Resolves an issue where some third-party effects generated green frames during render |
#5 |
Hi Dmitri.
Please re-read my post. |
#6 |
Ah, sorry!
#7 | ||
So .... what in the world is a "time reversed clip"? A clip showing something going backwards???
I still can't figure out if I really need it, or for that matter, if I could even use it. This was a fast upgrade (i.e., time required to download the new version) for once so that was a blessing. Last edited by John Nantz; April 1st, 2013 at 05:27 AM. Reason: reword last sentence about "upgrade" |
#8 | |
Can't wait to update. |
#9 |
"So .... what in the world is a "time reversed clip"? A clip showing something going backwards???
Yes. Last edited by Keith Ward; April 5th, 2013 at 09:31 PM. |
