Exporting as DPX file from FCP X at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old February 15th, 2013, 04:49 AM   #1
Is there any way to export your edited film as DPX files from FCP X?
Cheers,
Sabyasachi
Wild Tiger Productions
http://www.indiawilds.com/about.htm
Sabyasachi Patra is offline   Reply With Quote
Old February 15th, 2013, 07:56 AM   #2
Re: Exporting as DPX file from FCP X
If Compressor 4 has a DPX setting (I don't know), you can export in FCPX using 'a Compressor setting'. Then just make a DPX setting.
Mathieu Ghekiere is offline   Reply With Quote
Old February 15th, 2013, 04:11 PM   #3
Read this:
Larry Jordan - Creating Log DPX Files | Final Cut Pro Training | The Best Training in Final Cut Pro
Old February 18th, 2013, 12:26 AM   #4
Hi,
I just discovered this.
In FCP X, go to Share>Image Sequence>select DPX
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
