Apple ProRes HQ 1080p 25fps conversion to 24fps at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old July 21st, 2012, 02:15 PM   #1
Friends,
May I ask, is there a simple way to output Apple ProRes HQ 1080p 25fps to 24fps? Please forgive me if this topic has been discussed already elsewhere. If you know about an article covering this, please include a link in this thread. Many thanks.
Pavel
The fish is the last to know the water.
Pavel Tomanec is offline   Reply With Quote
Old July 22nd, 2012, 05:54 AM   #2
Re: Apple ProRes HQ 1080p 25fps conversion to 24fps
Compressor can do this. I believe it is in the frame control tab. You would pick 24 as the frame rate and check a box that changes the playback rate but keeps all the frames without blending frames. The sound will change and you might need to adjust the pitch.
Old July 24th, 2012, 06:37 AM   #3
Thank you William. I looked at it, and it seems that a preset is there only for conversion 24fps to 25fps.
I found this article:
https://truelove.zendesk.com/entries...ple-compressor
and am following it. Will see how it will look like at the end of the day and keep you posted.
Old July 24th, 2012, 01:30 PM   #4
Looking further into the matter, I found that Cinema Tools do much better job in conforming the footage. Oh well, it is all part of the constant practice and detachment from the results ...
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
