Colour balance in FCP X compared to Colour at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old May 24th, 2012, 09:24 AM   #1
Hello all,
Am starting to finish my first real piece using FCP X which involves a lot of colour correction. I am coming over from FCP and using colour to do my correction.
I somehow feel that for doing things like White balance on some shots is a bit more complicated and harder to get spot on than from when i used colour. In colour you could pick out where your inbalance was using the RGB parade and then using the curves easily balance them, however in the colour correction in FCP X its harder to move one colour up and another down as you have to move part of another colour, if that makes sense. do you use multiple corrections to get round this? or what method would you use.
Does anyone else find the same.
Lights and darks are fine.
thanks
Dave
David Tripp is offline   Reply With Quote
Old May 29th, 2012, 07:35 AM   #2
Re: Colour balance in FCP X compared to Colour
If you want to do serious colour grading I wouldn't recommend to do it inside FCP X. The tools are too limited and the fact that you can display only 1 scope at a time doesn't help either. Overall it will take a lot more time than doing it in for example DaVinci Resolve.
If you don't mind learning a new application, you can download the free DaVinci Resolve Lite from the blackmagic-design web site.
regards,
Winfried
Winfried Dobbe is offline   Reply With Quote
Old May 29th, 2012, 08:39 AM   #3
This is one of the reasons I've not upgraded (pun?) to FCPx... Recent gigs have been doing grading, so I am firmly in Color/FCS2 for the time being.
Web Youtube Facebook
Cole McDonald is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
