How much RAM is too much? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old May 1st, 2012, 11:30 PM   #1
Hi,
I'm running an iMac11,1 with 2 x 2 gig RAM. It has two empty slots, and can accept 4 gigs in each slot for a total of 16 gigs. It's easy to upgrade. I'm using FCP X, putting together half-hour TV episodes, but nothing fancy. Will I see any benefit from upping from 4 gig to 8, 12 or 16? I'll be using Motion too.
Richard
Richard Cavell is offline   Reply With Quote
Old May 2nd, 2012, 12:54 AM   #2
Re: How much RAM is too much?
It is only too much RAM if the additional memory causes hardware or software malfunction. I would be surprised if additional RAM caused overheating or timing related memory errors; however, such things have happened in the past. Similarly, I'd expect FCPX and the latest version of OS/X to work well with more memory; however, strange things can happen with 32-bit programs when you go beyond 4GB.
Unless you have a year-end budget that needs to be spent, I suggest leaving a working machine alone. Buy a backup RAID instead.
Eric Olson is offline   Reply With Quote
Old May 2nd, 2012, 11:40 AM   #3
Moving up to 16GB will give a major boost to performance. Go for it!!
Geoff Addis is offline   Reply With Quote
Old May 2nd, 2012, 12:08 PM   #4
The only way to have too much ram (assuming you have a 64bit operating system) is to have more memory sticks than will physically fit in the machine. ;)
In practice though you reach the point of reasonable diminishing return between 12-16gig of ram.
http://www.LandYachtMedia.com
Chris Medico is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
