Canon 5D MK lll footage at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old April 10th, 2012, 06:07 PM   #1
Anybody edited 5D3 footage with FCPX?
Charles Newcomb is offline   Reply With Quote
Old April 21st, 2012, 12:38 AM   #2
Re: Canon 5D MK lll footage
Yes. So far so good. Much easier to import (as well as make proxies) compared to FCP 6 (which I was using up until switching to FCPX). I'm working on a project with a 39 angle multicam clip, and with proxy playback, it's working pretty smoothly on my aging Mac Pro 1,1.
Jim Newberry is offline   Reply With Quote
Old May 16th, 2012, 09:39 AM   #3
Jim, what workflow are you using, if you don't mind sharing.
Charlie
Charlie Branham is offline   Reply With Quote
Old June 20th, 2012, 03:19 PM   #4
Does the Mark III show up in Camera Import? I'm not seeing it 10.0.4. I can import entire files off the camera's card or from my hard drive, but I'd like to be able to select in and our points.
Matt Lawrence is offline   Reply With Quote
Old June 20th, 2012, 08:43 PM   #5
Since I posted this I have purchased and used the MK lll. I do not import from the camera. I just stick the SDHC card into the Mac and import the files I want to a folder, which I then use to create a new event. When I use CF cards, I do the same via USB.
The files import nicely into FCPX. I almost always let it convert to ProRes in the background. It seems to go faster than files from my MK ll.
One thing you need to watch: The MK lll images are a little softer than the MK ll, but adding a little sharpening when needed makes that issue go away.
As far as in and out points are concerned, I set those in the event browser.
Overall, I'm very pleased with the camera and the software.
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
