Target Seperate internal Sata II drive for rendering? at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old February 5th, 2012, 12:40 PM   #1
I see render lumped in with project files by default. Lets say 6 or 7 weddings in process (approximately 1.5 TB), hypothetically, if all render files write to that same drive my 2TB disk will be full. That is why in FCP7 I have always assigned the render files to another 2TB internal drive. I can't do this any more with FCPX?
Craig Terott is offline   Reply With Quote
Old February 5th, 2012, 08:41 PM   #2
Re: Target Seperate internal Sata II drive for rendering?
As far as I can tell, not at the moment. What I do is assign different drives for different entire projects and events. In a way it makes everything easier.
Old February 6th, 2012, 06:54 AM   #3
My workflow is not to render since I'm using Sparse Disk Images for each new event on a MacBook Pro. If you're keen to render, there's an option to delete the render files after you've completed the project.
Scott Cassie is offline   Reply With Quote
Old February 6th, 2012, 08:40 AM   #4
Are you saying you turn off the background rendering?
Old February 6th, 2012, 09:44 AM   #5
Yeh I have that turned off. It's a pretty cool feature, but just doesn't fit in with my workflow.
The laptop handles AVCHD natively very well, and can play back transitions & effects without rendering just fine (got the 'playback quality' option set to Better Performance).
Old February 6th, 2012, 01:39 PM   #6
I do what William does. Have a single drive for a single project. I know thats overkill, especially since most of my footage is 720p. But I like it.
Though I am getting a new mac book soon and my work flow will be changing.
6-7 weddings at a time! Holy jeebus! No thanks.
Caleb Reynolds is offline   Reply
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
