Can't break up Compound Clips at DVinfo.net
Go Back   DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
Final Cut Pro X
The latest version of FCP from Apple.
Old October 18th, 2011, 12:38 PM   #1
So, weird thing is going on right now. I'm working on a project Right now, and I had collapsed some things down into Compound Clips. Now I want to break them apart and change some things, which I've done plenty of time in other situations, but it won't let me. When I select the compound clip and right click, the options to break apart clip items is dark, and it won't let me click it or use the hot key. This is odd. There another compound clip in the same project that I can break apart no problem.
Any ideas?
Fullerton Images - Vimeo - FaceBook
Ben Fullerton is offline   Reply With Quote
Old October 18th, 2011, 12:57 PM   #2
Re: Can't break up Compound Clips
Figured this one out on my own eventually, but thought I would leave this up in ase anyone else runs into this issue.
After grouping the clips together, I had retimed the whole connected clip. apparently once you do that, you can't break it apart. Once I had set the time back to 100%, I was able to break the clips back apart.
Live and learn. Fun times with X!
  You are here: DV Info Net > Apple / Mac Post Production Solutions > Final Cut Pro X
